Old 05-06-2005, 06:13 PM
david@ronsraceshop's Avatar
david@ronsraceshop david@ronsraceshop is offline
Default The Best Machine Shop
Looking for a Machine Shop do Some Machine on a Block I have. The work is very extensive and must be perfect when done
Just a Few thing I need done.
1. Derust and Clean
2. Bore On Center of Crank Rod Journals
3. Line Hone Crank Journals
4. Line Hone Cam Journals
5. Deck block @ 90degrees from Crank Mains
6. Square the Bell Housing Surface
7. Square the Oil Pan Gasket Surface
8. Square the Timming Gasket Surface
9. R & R Sleeved Cylinder
Just to name few things I need done to an engine I'm building
Any Shop Names and Locations and or Phone Numbers would be great
David@RonsRaceShop
VP RonsRaceShop
1971 RS Camaro
SBC 396 cid .... Comming Soon
ATS Spindles ..... Comming soon
14" Corvette Brakes with 6 piston Calipers ... Comming Soon
Tremec TKO-600
ROH 18x8 Front Toyo Proxes T1s
ROH 18x10 Front Toyo Proxes T1s
100-0 .... 185ft
60-0 ...... 110ft
13.40 1/4 mile
109 MPH 1/4 mile
Old 05-10-2005, 10:49 AM
airrj1's Avatar
airrj1 airrj1 is offline
Default CNC Blocks Northeast
Checkout: http://www.cncblocksnortheast.com/
I have not personally had work done by Carl, but he has been a contributor over @ Team Chevelle for a few years now and his shop appears to be very capable of the work that you are looking for. It have talked to Carl about a few jobs, I just haven't needed his services yet. I will be sending my next project to him.
Good Luck.
R.J.
Old 05-10-2005, 07:20 PM
JamesJ JamesJ is offline
You could call Joe Dahi at DRT AUTO, LTD in Phoenix. He was the one who did lots of work on the guy who has the green 69 that was in PHR last month. I dont think Joe does any motor work but he may be able to send you in the right direction. You could also call So-Cal speed shop in Phoenix they may have a good lead as well.
