Originally Posted by Keith
So what about bone stock non-power adder applications? According to the site those numbers posted are from a n/a car. Now, I'm a born skeptic and I know you can write yourself a few good bunk testomonials but these people have alot of testimonials saying what a miracle product it is....I'm tempted to try it and see what's up. My daily car I use haul stuff around is a 93 Ford Escort that's in perfect condition, a little dirty a times with a few dings but fine as is. It's a 1.9 roller motor with a 5spd. I replaced the motor November before last myself when the #4 exhaust valve dropped in the chamber and chewed it up. I wouldn't mind hooking this up for fun. Anyone forsee any real potential gains or am I just wasting my time?
The water injection won't net you any horsepower unless you have knock sensors that won't let you run the timing you want.
What water injection will do is let your engine act like its running a higher octane gas, and allow you to run more timing and more compression. Personnally, I think its a bandaid, but then most people don't want to coin up for av-gas, or race fuel. I believe that you could mix methanol with your gasoline and have a similar effect, but I could be way off base.
