Old 11-12-2018, 09:42 AM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Default BLACK FRIDAY NOW! AAW Classic Update Wiring Harness Kits
The sale starts today, Nov. 12th and runs through Friday, Nov. 30th.
MANY KITS IN STOCK IN OUR WAREHOUSE, READY FOR SAME DAY SHIPPING!
Kit prices are too low to advertise, please PM, call or Email for your quote.
Free Shipping in the 48 states plus the best prices of the year!
The AAW Classic Update kit is one of the most successful bumper to bumper kits to ever hit the classic car/truck market. They offer the new ATO plastic style fuses, high quality wire and insulation, they label EVERY wire every 4" for ease of install and after build mods or trouble shooting, they leave the headlight, engine and tail light harness extra long for hidden/custom routing as well. They truly have thought of it all and nailed it with these kits!
Most everyone knows someone running this harness or has used one in a prior build and will now use nothing but these! The feedback on these is incredible.
For a FAST Black Friday quote please contact us by:
Send a PM
Email: [email protected]
TEXT ONLY: 925-989-9091
CALL: 925-828-5555 (8-4 Pacific, 11-7 Eastern)
Thanks,
MCB PARTS
Some notable features on the kits are:
- Includes a replacement headlight switch with internal 30amp circuit breaker, retention collar nut, adjustable length shaft, and custom knob.
- Standard turn signal flasher, hazard flasher mounted on fuse panel, and horn relay mounted on harness
- Fuse box designed to fit in original location with slight firewall modification on some kits, some are direct-fit. (Template is included if trimming is needed).
- All required hardware supplied.
- New ATO fuse panel allows for easy fuse and circuit breaker accessibility.
- Harness is laid out and formed to allow for nearly all after market accessories such as; gauge packages, wiper systems, heat and air conditioning systems, etc.
- Original switch connector bodies - an American Autowire exclusive feature
- Steering column connectors can plug directly into most aftermarket steering columns or stock GM columns that use stock GM turn signal switches.
- Separate under dash courtesy lamps for use along with your original dome/interior lighting.
- Instrument Cluster wiring is designed with a “cluster harness disconnect” system for easy service and assembly. Original terminals, connectors (another American Autowire exclusive), and light sockets are supplied for stock cluster connections. The system will also connect into most popular aftermarket gauges such as AUTOMETER, CLASSIC INSTRUMENTS, DAKOTA DIGITAL, STEWART WARNER, VDO and others.
- Rear body harness assembly plugs into the main harness in the stock location and our longer leads allow for stock or custom routing the wires. Rear body wiring includes backup light lead wires with rubber connectors, stop and tail light lead wires with correct light sockets and boot/tube assemblies for Fleetside trucks, or correct connections and terminals to mate with the tail lamp assemblies for Stepside trucks, license plate connection wire, side marker lead and ground wires with lamp sockets, and fuel tank sender wire and connection.
- New floor dimmer switch is provided with extra long mounting screws for ease of installation. Wire length and connection accommodate original floor mount dimmer switch.
- GM bulkhead connectors for the engine and front light wiring are included (another American Autowire exclusive) and allow for easy installation with original or custom routing.
- Engine wiring includes connectors for original points type as well as H.E.I. distributors. Power and tach connectors supplied for GM H.E.I. distributors. Alternator connectors are supplied for GM “SI” series internally regulated alternators. GM “CS” series alternator adapter is available separately.
- Front lighting includes extra long leads that can be routed for stock or optional appearances. All headlight, park light and directional light connectors and terminals are provided (including 1967 only parking lamp adapter extensions) along with a switched trigger wire for an electric fan relay (usually recommended with AC).
- Original style light sockets, connectors, terminals, etc. packed into every aspect of this harness, it makes it the most complete system of its type in the industry!
69-72 Kit show here in Hi-res for great detail, if you need pics, let me know.
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 11-23-2018, 08:52 AM
MCB Matt's Avatar
Thank you to everyone who has placed their orders, we appreciate your business.
We are here today, Black Friday 8-4 Pacific at 925-828-5555, ready for you orders and quotes. Please be patient as this is our busiest day of the year and we are working HARD to get everyone taken care of.
We hope you had a LOT of Turkey last night and have the day to kick back!
MCB Crew
Benicia, Ca. 94510
866-628-8746
www.mcbparts.com
