I'm using a Quicktime RM-8020 bellhousing for my LSA/T56 setup and it didn't require any modification to make it work. The Quicktime bellhousing says it will work for LS1 and LS2 blocks as well, so it seems to me that the bellhousing you have should work also since it claims to support those same blocks. Or maybe the starter you're using has an unusually long nose??
