Old 07-06-2015, 08:22 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Default Custom A/C Hard Lines for Compressor
I'm looking to have some custom hard lines made for my Vintage Air set up. I changed the rear compressor cover to the rear exit lines versus the suppied top exit. The 135 degree fittings Vintage Air supplied are very close but the discharge side hits the bottom of the cover before the fitting gets tight. I'd like to use the 135 degree fitting make the angle a little smaller to clear the rear cover and then a small straight run with a beadlock fitting that sits under the compressor instead of pointing down at that angle. Vintage Air acted like they didn't want my business today, so I'm done with them. Any ideas who can make some custom fittings? Thanks in advance.
Chris
Old 07-06-2015, 08:52 PM
dontlifttoshift's Avatar
Buy the universal hardlines, bend to fit, soup.
Donny
