Old 11-14-2014, 07:26 AM
rickpaw rickpaw is offline
Default What's a typical drain on a battery while connected to a car?
My car is a 67 Firebird, with 5.3/4l60e swap. The vehicle wiring had been replaced with American Autowire classic update kit. Engine harness is from PSI wiring. Battery is located in the trunk.
The other day, I hooked up my meter in series to the battery neg post, and it read around 0.5A (everything was off). I pulled the relay for the PSI harness main fuse panel, and the reading dropped to 0.002A.
Wonder if these numbers are normal?
Tu Ho
Old 11-14-2014, 08:30 AM
mitch_04 mitch_04 is offline
Most every time I look up the allowed drain on newer vehicles while chasing a draw, its .25 amps or less.
Old 11-14-2014, 10:54 AM
dontlifttoshift's Avatar
When you got .50 amps, who long had it been since they had been on?
I don't recall the actual timing but it takes a while for the ecm to go to sleep mode.
Donny
Old 11-14-2014, 12:13 PM
The car had been sitting less than 24 hr since I last ran it, when I made the measurement.
Tu Ho
Old 11-14-2014, 07:54 PM
68EFIvert 68EFIvert is offline
I had a very similar situation with my Ford harness. I eventually tracked it down to a relay that was stuck in the open position. It was a real pain in the rear to find though.
Darreld
Old 11-14-2014, 09:02 PM
dale68z dale68z is offline
yes.
Make sure you allow the system to time out. I have had to wait an hour sometimes.
Old 11-15-2014, 08:09 AM
Darreld
Now think of it, I think the relay for the engine harness may be stuck also. Pulling the relay should not make any difference in the amp draw, correct?
Tu Ho
Old 11-15-2014, 09:29 AM
How we find them is take the negative battery cable off, hook up a multimeter between the cable and the post with the multimeter on amperage setting, and then start pulling fuses until the draw drops. Have the door open but the door switch closed, that way you can access interior fuses but it won't be trying to turn on the dome light and similar accessories. You can also use a test light in place of the multimeter, just wait for the light to go out when you pull a fuse. However, with a tiny draw it's hard to see.
Old 11-15-2014, 03:19 PM
That's what I did. Pulled the main relay feeding the engine harness fuse panel, and the amp draw dropped from 0.5A to around 0.002A.
Tu Ho
