Old 01-26-2014, 09:45 PM
SWAPMEETCRAZY's Avatar
SWAPMEETCRAZY SWAPMEETCRAZY is offline
Default Any vendor that may have Marquez C10 tailights & markers?
Looking for polished taillites and markers for 68 c10..I know the problems with getting Marquez's stuff...just wondering if any one on here may be stocking a set..........thanx......jim
Old 01-27-2014, 06:18 AM
ccracin's Avatar
ccracin ccracin is offline
Jim,
Check with Muscle Rodz or Digi-Tails. They are both dealers, not sure about stock. Digi-Tails makes the LED boards for them. Good Luck. I tried for 2 years just to get a picture of them and never did. I'm making my own!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 01-27-2014, 10:27 AM
Mike was having trouble getting them....think i just got them from digitails..Chris (Fesler) doesn't have markers ready yet from my understanding...wanting both.....we will see if Marquez delivers...check out the "coffin" I'm sending off to have Scott's shave the cowl!!
jim
Old 01-27-2014, 10:33 AM
ccracin's Avatar
I thought Digi-Tails said they had some. They made the LED panel for my lights. I'm not doing side markers on ours. Let me know if you like the cowl when you get it back and how much. It may not be worth me smoothing ours. Nice crate eerrr coffin!
Chad
Instagram - @cctek
Old 01-27-2014, 01:37 PM
Musclerodz's Avatar
Originally Posted by garickman View Post
Do your homework on getting products from Marquez Design. Keep in mind also that Marquez C-10 side markers and not actually side markers. They are to act as reflectors only and even that is a stretch because the material used is not reflectorized. There is no lighting bucket for these and they WILL NOT fit over the factory markers. If you want to use these as side markers you will have to fabricate your own housings and supply your own lighting options.
the 71 and 72 model have actual side markers, not just reflectors.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-27-2014, 01:40 PM
ccracin's Avatar
Mike,
Does that mean the Marquez side markers for the 71 and 72 are actual lights or lenses that will cover the actual lights?
Thanks!
Chad
Instagram - @cctek
Old 01-27-2014, 01:54 PM
Musclerodz's Avatar
Originally Posted by ccracin View Post
Mike,
Thanks!
yes, they are suppose to
Mike Redpath
facebook page
Old 01-27-2014, 02:10 PM
ccracin's Avatar
THANKS MIKE!
Chad
Instagram - @cctek
Old 01-27-2014, 05:17 PM
According to the staff at digitails...they have the lighting option...Chad it is a lense with bulb option.....I actually want the non bulb
type because on my truck they both open on rear for gas filler on driver side ......battery charging posts ( rear mounted batteries under raised floor) on pass side...Floor is
high enough to make both mods easy.....
We will see WHEN they arrive!..............jim
Old 02-06-2014, 08:05 PM
10 days after order from digitails..got them delivered directly from Marquez. ..makes u wonder!!......they are really nice pieces...jim
