Old 02-03-2013, 12:45 PM
marks914's Avatar
marks914 marks914 is offline
Regular User
Default Fox Mustang Performance gauge cluster 87-93 from NVU
NVU GAUGE PACKAGES FOR 87-93 MUSTANG
87004-01 87-93 MUSTANG PACKAGE PERF2 BLACK
87004-03 87-93 MUSTANG PACKAGE PERF2 WHITE
87004-04 87-93 MUSTANG PACKAGE PERF2 SILVER
Replace and upgrade your factory cluster with the most advanced, kit available on the market for 78-93 Mustangs. Kit includes NVU Performance II backlit stepper motor gauges in 3 colors with programmable warnings and outputs. You can control the high/low dash warnings as yo see fit. Gauges offer full sweep stepper motor technology, backlit through the dial LED lighting in BLUE. Gauges feature polished stainless bezels for a high end look and flat glass lenses. Electronic speedometer is easily calibrated to your vehicle and operates from stock VSS signal or aftermarket sender (not included)The NVU mounting plate is constructed of laminated, CNC laser cut ABS and polycarbonate for superior strength and light weight. Integrated into the panel are NVU’s exclusive deadfronted indicator lamps; black, invisible when off, brilliant colors when on. Assembly installs in factory location, OE cluster cover can be used in addition to panel for a finished, OE look.
Kit includes:
87-93 Mustang panel with 14 warning lamps
Performance II 6 gauge kit for Mustang : Programmable speedometer, tachometer, fuel level (Ford match 20-150), water temp, oil pressure and volt gauges. Temperature sender, Pressure sender and adapter bushings for sender installation. Wiring harnesses for gauges and warning lamps included. (speed sender may be required)
Instruction booklet and wiring diagram
www.newvintageusa.com
Old 02-03-2013, 01:32 PM
wiedemab's Avatar
wiedemab wiedemab is offline
Awesome! I wish this was out back when I had my Fox Coupe....would have picked a set up for sure.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
