Old 01-27-2013, 11:45 PM
hotrod69camaro's Avatar
hotrod69camaro hotrod69camaro is offline
Default 67-69 Camaro Sub Frame
67-69 camaro sub frame. This sub frame was removed from my car I've owned since 2000. It has had the Guldstrand mod done at the upper control arm attach pad. It has Speed Tech tubular upper control arms with stainless shafts and Del-rin bushings. It has Speed Tech tubular lower control arms. The steering box was sent to Lee Steering and reworked to add feel and change the steering ratio as well as a full rebuild. It has a Baer brake system with 13 inch two piece rotors with aluminum center hat, rotors are drilled and slotted with 4 piston calipers. 16 inch wheels fit over these brakes. I also have the correct master cylinder that came with this brake system and a 9 inch dual diaphram booster. I has a Baer tracker outer tie rod system to eliminate bump steer. It has a QA1 coilover shock setup with Global West springs and double adjustable shocks. Hotchkis hollow front sway bar with Guldstrand Hiem joint end links. All these parts that were added to this subframe have 5000 miles on them. Assembeled with ARP grade 8 stainless fasteners. $2500.00... (Also would like to sell the aluminum inner fenders I had fabricated that you see in the picture)...Call Mike..(714) 504-7315...Thanks
Old 01-28-2013, 03:58 PM
intocarss's Avatar
How much for the inner fender wells?
Old 01-28-2013, 05:15 PM
syborg tt's Avatar
I'm with him how much for the inner fenders and what size front tire were you planning on running ?
marty-mj
Old 01-29-2013, 12:10 AM
Default Inner fenders
Im gonna say a grand for the inner fenders. Fast Eddie charged me over double than that. Im not trying to recover all of it. they are one off parts and everybody that sees them comments on how nice they look. But the main thing I like is the ease of servicing the car when they are removed. It takes about 20 to remove them. I'll negotiate, lets deal.......Mike
Old 01-29-2013, 05:29 AM
GLWS.. honestly that is a gret deal.. inner fender aside that sub and parts is a real bargin!
Old 01-29-2013, 07:41 AM
CHAZMO1986's Avatar
CHAZMO1986 CHAZMO1986 is offline
Default subframe
Any interest in shipping?? 72601 zip code, Harrison, AR
Old 06-10-2013, 09:50 PM
cwylie cwylie is offline
Still have it?
Old 06-14-2013, 06:37 PM
I still got the inner fenders
Old 06-14-2013, 10:51 PM
31069ss's Avatar
31069ss 31069ss is offline
Is the frame still availble
Old 08-25-2013, 10:17 PM
jimboR831 jimboR831 is offline
Willing to part out the swaybar?
