Old 10-06-2012, 12:58 PM
gnx7's Avatar
gnx7 gnx7 is offline
Default options to remove factory wiper motor and retain functionality? Smooth firewall.....
I'm planning on running the new Wilwood brake/clutch pedal box setup which removes the master cylinder from the firewall and puts it under the dash with individual masters for each and a balance bar for the brakes.
That leaves me with the fugly factory wiper motor on the firewall. How can I remove that system and upgrade it to something more stealthy that isn't as bulky or even located on the firewall?
Any/all ideas are welcome! I would like to retain the factory the wiper functionality. 1969 Chevelle
Old 10-06-2012, 02:22 PM
Rick D's Avatar
Rick D Rick D is offline
http://www.pacificwesterndesign.com/
They don't have one for a Chevelle but I'm sure you can make it work.
Worth a shot!
Rick
Old 10-06-2012, 03:45 PM
John510's Avatar
John510 John510 is offline
Where do you plan on putting the remote cylinders?
[SIGPIC][/SIGPIC]
Old 10-08-2012, 09:36 AM
gnx7's Avatar
Thanks for that wiper option!
If they don't fit under the steering column one can mount the reservoirs remotely via braided steel lines; however the master cylinders themselves must be by the pedals.
This is my old race car that runs a Tilton pedal box ($$$) with the reservoirs mounted on the dash for easy access. The entire chassis was powdercoated inside/out. Mazda RX-7 with 438ci LS7, GForce GSR dogbox, 8.8" IRS rear, 2400lbs.
Old 10-17-2012, 02:31 PM
gnx7's Avatar
any other options people know of?
Old 10-21-2012, 11:13 AM
Try searching for windshield wiper remote drive systems. There are a couple out there.
Some buildiers here have used this one by speciality Power Systems.
http://www.specialtypowerwindows.com/products.php?c=2
This one is a cable drive system and it allows you to hide the drive motor under the dash or in the kick panel area.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 10-21-2012, 01:56 PM
Rick D's Avatar
Um can we see some more pictures of the Mazda?? You can just show that one picture and that's all
Rick
Old 10-22-2012, 12:09 AM
Vince@Meanstreets's Avatar
you can also make an extension rod and put your stock motor further into the drivers side.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 11-15-2012, 06:58 PM
gnx7's Avatar
Thanks Vince and everyone else.
That is the last thing I need to tackle; however since I want to run the brake/clutch reservoirs under the dash with a Tilton/Wilwood pedal assembly I may as well try to hide the wiper motor as well!
