Closed Thread
Old 07-10-2012, 05:25 PM
rchandler's Avatar
rchandler rchandler is offline
Default Small Block Chevy complete engine
For Sale
Edelbrock 435 hp 435 tq Performer RPM E-Tec crate engine.
GM ZZ-350 short block, 4 bolt blk, 1 pc main seal forged crank, powered metal rods and hypereutectic pistons, 9.5:1 compression.
Edelbrock hydraulic roller cam, 234 -238 deg @ 0.50, .539"/.548" lift.
Edelbrock Performer E-Tec Aluminum heads.
Aluminum roller rockers.
RPM Air Gap intake.
Pro-Systems 780 CFM holly 4150 custom built carb.
MSD Pro-Billet distributor & 8mm wires
Milodon oil pan.
Edelbrock 110 gph mechanical fuel pump.
less than 4000 miles. First 400 mi on Royal Purple break in oil, then 2 synthetic oil changes since. Like new condition, 35 psi oil press @ 750 RPM idle, No leaks, runs great.
Edelbrock PN 45910
Located in Sacramento CA area
$3,500
Old 07-10-2012, 06:50 PM
sevillaz28's Avatar
sevillaz28 sevillaz28 is offline
Hey. I have a guy looking for an engine. If you can get me your number I will check tomorrow and if hes serious I will give him your number or his number to you what ever works for you.
Thanks, John
[email protected]
Old 07-23-2012, 07:16 PM
GRob GRob is offline
Just wondering if this is still available.
Old 07-24-2012, 11:04 AM
rchandler's Avatar
Yes it is
Rob
Old 07-30-2012, 04:44 PM
The T-man The T-man is offline
I rode in the car w/ this engine
it's STRONG
Old 08-14-2012, 12:20 PM
rchandler's Avatar
Sold thanks
Closed Thread
