Yes, the Delrin bushing has an inner metal sleeve that takes the compression of the tightened bolt that runs through it. The Delrin bushing has grooves in it to allow grease to lubricate the inner surface that mates up against this inner metal sleeve, and it has grooves on the outside of it where it mates against the inside of the control arm. Whether the bushing rotates on the inner sleeve surface or on the control arm surface is NOT my concern since those have grease grooves to lubricate them. Where the Delrin bushing does NOT have grease grooves is the outside surfaces visible to the naked eye that mate up against the frame. Those are surfaces that I wonder about because those are the surfaces that are rotating against the frame surface. Yes, I can put some grease on those surfaces now before installing(not mentioned in the Hotchkis instructions), but once they are in, there are no grooves on that surface to keep it lubricated in the future. Additionally the frame surface is not perfectly smooth like the other surfaces, so the Delrin plastic rotating on would seem to wear. It's just strange to me that I'm seeing this plastic rotating against this rougher frame metal and knowing that when I pump grease into the grease fitting the grease is not going to reach that surface. I guess time will tell. I know lots of people are running Delrin bushings so I guess I'm just being paranoid. If, 5K miles from now, I see those bearing surfaces worn out with slop resulting, I'll print out this thread and send it to the makers of those bushings that Hotchkis is using.
Can't wait to put these new arms to good use along with my other Hotchkis gear.
Thanks for your input gentlemen.
