Originally Posted by HRD
Educate me on the difference between the GTO and the F body bell housing.
They are almost identical actually. The only difference being where the starter is. You can use either a F body or GTO bell housing with a GTO starter, but you can't use a F body starter in a GTO bell, unless you grind to allow room for the starter to engage. Weird I know, but that is the difference.
They are identical in dimensions and spacing. I bought a GTO T56 and have a F body starter, so I picked up the F body bell. Then I ended up buying a quicktime bell so I now I don't need either one.
