Old 07-13-2011, 03:27 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Default Aeromotive 11104 Eliminator Fuel Pump
Brand New in the box. never mounted to anything. had to go with different pump. my loss your gain! Price $435 shipped.
From Aeromotive site.
This continuous duty “street warrior” supports big horsepower and maintains the drivability necessary for a true high performance street car. Designed for high horsepower street/strip applications, EFI or Carbureted, it features our “dual chamber” pumping mechanism.
Fuel Injected Engines:
up to 1900 HP – naturally aspirated
up to 1400 HP – forced air induction
Carbureted Engines:
up to 2300 HP – naturally aspirated
up to 1700 HP – forced air induction
• ORB-12 inlet port and ORB-10 outlet port.
• For EFI applications use regulator P/N 13110, carbureted P/N 13212.
• Fully submersible for custom, in-tank placement.
• 25% more flow at pressure than our A1000 Fuel Pump.
• Perfect for “blow-through” carbureted engines up to 1700 HP.
• Billet Speed Pump Controller (P/N 16306) recommended for EFI street applications.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 07-14-2011, 06:49 PM
aronhk_md's Avatar
aronhk_md aronhk_md is offline
Wish it was in the budget right now....almost bought a lightly used one off ebay a few months back. I'd like to do fuel injection and my A1000 isnt enough for that. Then again, I cant afford the rest of the injection right now with all the other changes I'm making to the car....lol. Good luck on the sale, its a good price.
1973 Trans Am
73 455 SR block, ported 6x-8 heads, solid cam, Victor intake, 830 CSU carb, aluminum rods
oh.......did I mention the 77mm Garrett turbo and methanol injection?
886 hp at the rear wheels, 1064 at the flywheel (calculated)@5500 rpm, before the methanol injection was added. Thank you Mark L...
