Old 10-30-2010, 10:58 PM
Steve88 Steve88 is offline
Default Gearvendors Overdrive Set up for Turbo 400
I have a complete Gearvendors Overdrive set up for a turbo 400. You get everything you need to bolt the set up on and go. It comes with the Gearvendors unit, electronics, turbo 400 adapter and the required coupling. $1425 plus shipping. Thanks
Steve
Old 10-30-2010, 11:35 PM
You had one for sale a while ago for 850. is this the same one? Whats the mileage on it? pics?
Old 10-30-2010, 11:41 PM
This is a different unit. The one I had before was just a GV unit with a Ford C6 adapter. This is a complete set up with all electronics, turbo 400 adapter and coupling. I am unsure of the mileage. It came from an early 90's Chevy pickup and I rode in the truck to verify it was working correctly when removed.
Old 10-31-2010, 10:38 PM
SuperSport's Avatar
SuperSport SuperSport is offline
Where are you located? Interested.
Thanks.
Old 10-31-2010, 11:02 PM
Thanks.
I am located in Springfield MO
Old 11-01-2010, 07:05 AM
g356gear's Avatar
g356gear g356gear is offline
Pics??
69 SS396 Camaro Coupe, 4link, 12bolt posi, Speedtech LCA and UCA's, Hotchkis 2" drop springs and sway bar, Ridetech triple remote resevoir coilovers, Bilsteins, Wilwood 6 piston front/4 piston rear, Magnaflow stainless exhaust, Lemons Headers, Comp rollers/p-rods/cam, Fikse 18x8.5 and 18x10
Old 11-01-2010, 10:53 PM
Herr are a few pics of the unit. I have everything needed to install including all wiring, coupling, VSS speedo adapter and the floor mounted switch.
