Old 10-27-2010, 08:50 PM
clay69camaro's Avatar
clay69camaro clay69camaro is offline
Default Roof removal and replacement
Well the roof had some frankenstein work done too it before I bought the car. Looks like the roof skin from another camaro was bondo'd in place.
I found this out when I was grinding a LOT of bondo/fiberglass away from the rain gutters. It is a complete line with one skin on top of the other. (NOT cool previous owner) but I knew the car had it's problems when I bought it.
So how can I ditch the stock roof skin? I'm going to attempt installing a new one lol.
Where do I cut and how deep? Are there any spots welds I need to drill out? Are the rain gutters attached to the roof skin? since I want to remove them anyway shall I just do so?
Clay
Old 10-27-2010, 09:45 PM
kush69 kush69 is offline
I would get the new one before you do any cutting .just so you can see exactly what you get.then cut,grind ,drill as carefull as you can to remove the old skin.Also stripping the old paint off of the edges of the old skin helps hope that helps
Old 10-28-2010, 05:32 AM
GPR's Avatar
GPR GPR is offline
Clay
The roof is attached with spot welds in the drip rails, windshield and back glass area.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 10-28-2010, 05:41 AM
Smitty67 Smitty67 is offline
This thread should show you what you need to know. If not, just ask Todd.
http://www.camaros.net/forums/showth...46455&page=166
Old 10-28-2010, 06:34 AM
DOOM's Avatar
DOOM DOOM is offline
Lots of spot welds in the gutters!!!. I found it much to faster trim the roof off and drill the drip rails off alot less spot welds.....Weld in new gutters. I'll be gluing most of my roof on. It will be welded along the windshield and rear glass area then I'll glue the gutter . I'll put a weld at the ends and the center of the gutter area just for good measure.
Mario
USCOLLISION
Old 10-28-2010, 11:48 AM
Yes! Thank you everyone. I believe this answers all my questions. I will post up some pictures in a few weeks when the funds are available to buy a new roof skin. Till then I just have to stay vigilante and hope my DD does not break on me at auto-x lol
Old 10-31-2010, 11:00 PM
elitecustombody's Avatar
Buy a new skin first,use metal panel bonding adhesive on all pinchweld flanges, weld only on A and C pillars,
DOOM, there is no need to weld on pincheld flanges,only corners and sail , the adhesive is alot stronger than welding, if you have ever tried replacing bonded quarter or any other panels, you'd know.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 11-01-2010, 06:58 AM
DOOM's Avatar
Do it every day!
Mario
USCOLLISION
Old 11-01-2010, 06:19 PM
I agree with panel bonding ,also helps with rust between the seams
Old 11-01-2010, 09:20 PM
Originally Posted by DOOM View Post
Do it every day!
so why create more work for yourself and end up with weaker result and a chance for corrosion down the road?
Years ago I read an article in Bodyshop Business Magazine where they did a test on two Nissan Sentras,one with with glued on quarters and roof skin ,another with welded panels and dropped them from a crane lifting cars to 75 feet in air, the results clearly showed the car with bonded panels had won hands down,that's what has sold me,I've been using Duramix till few years ago,because 3M bought them out ,so now it's Automix, I also use SEM stuff and both work great,I would never weld ,unless the seam is on exterior,it makes watertight seal and is much stronger than weld,just my .02 cents
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
