Old 07-19-2010, 02:26 PM
Taman Taman is offline
Default SSB vacuum pump
I have a SSB electric vacuum pump and vacuum canister. I have all parts including the relay, pressure switch and instructions. Pump is mounted on 4 rubber pads on an aluminum plate drilled and tapped for easy mounting. Pump is 4 months of use. $150 plus shipping.
I switched to manual disc brakes and no longer need it.
Old 10-24-2010, 09:52 AM
cp87 cp87 is offline
Default Vacuum pump
pm sent
Old 01-09-2011, 07:45 PM
41 chevy 41 chevy is offline
Default vac pump
I know this is an old fourm but do you still have the vac pump? thanks
Old 01-12-2011, 07:58 PM
somewhere I have another pump. I just haven't found it. When I have time to clean out the garage I will look for it.
