Old 04-12-2010, 03:57 PM
speedshftr speedshftr is offline
Default are all valve seals the same in small blocks
are 327 the same as 350 seals thank you
Old 04-15-2010, 10:30 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
if you are talking about small block chevys, then yes they have an o ring seal on the second groove of the valve stem just below the keepers. I built cylinder heads for a few years and we ran small block ford umbrella seals because the chevy o rings suck.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
