Vortech Supercharger V2 kit
2003-2007 GM Vortec 6.0L V8 Hummer H2 Supercharging Systems
View larger image
Power Torque
Stock 316 HP 360 lb/ft
Vortech 436 HP* 465 lb/ft*
The Vortech supercharging system for the 2003-2007 H2 will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower from 316 to 436 and torque from 360 lb./ft. to 465 lb./ft.*
Quality Features:
Vortech gear driven supercharger with SQ technology provides nearly silent operation and unmatched reliability
Technologically advanced, high-efficiency impeller and housing design developed in Vortech's supercharger test cell
Integrated air/water, dual-pass charge cooler configuration allows for additional horsepower gains and features maintenance-free design
Oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger, even under sustained boost conditions
Inlet and discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps
OEM-type cast aluminum mounting bracket for "factory installed" appearance and rigidity
High-flow bypass valve provides surge-free compressor operation
Stock HP/TQ: 316/360
Vortech HP/TQ: 436/465
Boost (PSIG) 7-8
Includes High-flow fuel pump
CARB E.O. D-213-24
Part Number: 4GL218-078SQ
Shipping Weight: 90.00 lbs.
Price: $6284.95
New in the box missing supercharger to intercooler, has used intercooler and intercooling to throttlebody tube.
$3500 obo.
Located in Phoenix Arizona
