Old 07-29-2009, 09:38 PM
rogue rogue is offline
Default Buttonwillow this weekend
Last minute decision on my part. I need to scratch the track itch....
I'll be headed out saturday if anyone wants to come out. Speedventures puts on a great event, all you need is your car, a quick tech inspection and $170 for the day. Helmet rentals are available for $20...
http://speedventures.com/events/eventdetail.aspx?id=229
If any of you could rally I'd love to see some other pro-touring cars out there...
I'll be out there in this hunk o tin.
-Dane
Old 07-29-2009, 09:52 PM
ironworks's Avatar
I will be around this weekend if any of you guys want to do a shop tour and need guidance on the place to eat Saturday night. My shop is 20 minutes from the track.
Or if you need to wrench on something...
Rodger
Old 07-29-2009, 10:12 PM
Rodger
I didn't realize you guys were so close. If you're going to be around I'll surely cruise by. I'm in need of a shop I can trust to take my car to the next level when I finally make that jump.
You guys do amazing work!
-D
Old 07-29-2009, 10:13 PM
DFRESH's Avatar
DFRESH DFRESH is offline
Dane--next time can you give a bit more notice? I'd like to go to my first open track day with someone who knows what they are doing. I am trying to get mine out for some testing to see how inadequete both the car (Apollo 13) and I am on a track that isn't a straight line and a 1/4 mile long--LOL. I just finished up the Speedtech stuff and have the new Rushforth from Jon on the car. Needs an alignment then it's ready to try and get some baseline #'s on the car before the next set of mods.
Roger, when I do make it out there, I would really like to come by your shop and get some tips on my Extreme Drag Radial car--you know, the kind you give to your golden boy (Holder) who always wins.
I hope I don't enjoy these open track days more than heads up stuff--I hope it's a push---or Visa/MC will be forced to be my sponsors.
Doug
Old 07-29-2009, 10:45 PM
Doug
Yeah I'm horrible about doing these things last minute lately... I'll try and give some notice next time. It never seems like I can get people out there. Its probably my short notice every time.
My first track day I took my car out with stock leafs, rear shocks, rear drums no subframe connectors, a bad coil, no g mod and still had a great time. You can actually hear the motor cutting out over 4k RPM and at WOT on the straights. It took some dyno time to figure out the coil was the cause...
I came home with a list of things I needed to improve, and each time I go out, I come home with a new list. This time I'm going out just for fun, and to take out some aggression on the track. I need to rework my steering and add a proportion valve, but its not stopping me from going out.
I also enjoy all the great people I meet at the track as well. Such a friendly fun group. If you are concerned about getting hooked, you should be, its an absolute blast!
Old 07-29-2009, 11:11 PM
DFRESH's Avatar
Dane, seriously? So in those videos you were running with stock rear drum brakes, no frame connectors? That's right where I am at, but I wasn't sure if it would be ok to run like that. The front is setup with Upper and Lower Speedtechs, swaybar,DSE box and ATS spindles--Nitto tires all the way around on Rushforths--but just rearched leafs in back with poly bushings, DSE solid mounts--but alas, drums in the rear. What kind of top speed were you hitting--I love it when you pass the viper--he actually points you to pass. You are giving me hope here that I might be able to actually enjoy the car at the track and have a good time with it like this.
Great vids by the way---very, very cool.
Old 07-29-2009, 11:30 PM
Thanks for the compliment.
Seriously. Thats with qa1 coilovers, hotchkis front sway, stock subframe, no subframe connectors, stock leafs with lowering blocks, old shocks and rear drums. My car is a build in progress but theres no reason you can't enjoy it out there.
About 125-130 on the main straights and 110 or so in turn 1/2... I just padded my braking zone quite a bit and didn't push the limits too hard. You're not racing anyone, so your pace is really up to you. If someones on your tail, you give them a point by. Its really a safe environment to learn the limits of both yourself and your car. My car wasn't even running right that entire track day nor well sorted, but I still had a blast. Turned a 2:12.586 for the day.
It's not as safe as autocrossing, but a LOT more fun and you get a lot more seat time. Sessions are about 30 minutes and you get a 1-2 hour break between them to work on your car/rest whatever. There is a zero tolerance policy with unsafe drivers or people driving like idiots out there. Speedventures really is a great group to run with and Aaron runs a tight ship.
What is your tire setup?
Old 07-29-2009, 11:49 PM
DFRESH's Avatar
That is great!! I am much more drawn to a track day than I am to Auto X, but have not done either. It seems like a track day gives you a bunch more seat time and an opportunity for some real speed and driving.
On the car now, Nitto 555's, 235 35 19 and 275 35 20
Do you run a power steering cooler on your car?
Old 07-30-2009, 12:01 AM
You'll be fine with that rubber. You definitely get a lot of seat time and its a great learning experience. I have manual quick ratio steering, the car is a monster to drive. Power steering and a cooler are on the list, along with hydroboost eventually....
I'm BEAT by the end of the day.
Old 07-30-2009, 12:12 AM
DFRESH's Avatar
Ok, very cool. I really appreciate your input here. I noticed you have run the car on the Angles Crest Hwy. I know that there is a group that runs that stretch from time to time. That looks to be fun as well. Please keep me posted, as I think the next time you are able to make it out there, I will be ready to go and try it out. I will PM you my contact info.
Doug
