I thought those were the correct headders?
the cals1sb(the ones you had for sale that fit the factory frame with the steering box) is the headder for the speedtech frame,there is another one for the wane frame, But the ones you had should have been correct.If I am wrong let me know cuz I will be getting some soon,thanks. this is from speedtech's site:
"67-69 LS1 F-Body headers. 1 3/4" 16 gauge 304 Everlast Stainless Primary tubes. CNC laser cut flanges. Smooth formed collectors with 3" slip joint exhaust connection. 02 bungs installed in slip joint collector extension. Tig Welded. Standard finish. For use with our steering shaft kit or the factory steering box.These are the best fitting header and the only headers designed specifically for 67-69 Camaros/68-74 Novas with our sub frame or stock sub frame! Designed specificaly to work around a 2 joint one shaft steering kit for all Unisteer rack and pinion conversions. Made exclusively by Stainless Works."
Reason: adding info
