Old 01-17-2009, 01:05 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
Thumbs up Nice 350 Chevy For Sale Cheap!
350 chevy small block engine i took outta my v8 s10 truck.
less then 6k miles.
4 bolt main, 2 piece rear seal, gm crate-motor shortblock, dual dipstick.
edelbrock rpm heads/small chamber/2.02-1.60 valves.
holley dual plane intake manifold.
9.5:1 compression ratio.
accell hei distributor, taylor 409 wires in blue, msd cap/rotor, set up as pickup only; requires module or msd-type box to run.
comp 262 extreme juice cam with variable duration lifters and crane 1.6 full roller rockers
edelbrock timing set.
complete stem to stern, drop on a carb, add fluids and drive.
395HP/440 torque.
starter, water pump, pulleys included.
great running motor; the truck'd pull 1100 rpm up a hill in 6th gear and pulls hard to almost 6,000rpm; idles at 16" vacuum @ 850rpm; power brakes no problem.
$2800, NO SHIPPING!
SOLD!
don't be a dick
