Old 12-31-2008, 05:06 AM
MCMLXIX MCMLXIX is offline
Default 1971 C/10 Stepside 402 BBC Lowered Buckets 17's Las Vegas
I had two projects... This 1971 Stepside and my 67 Chevelle. I decided to sell the truck to finance my build up on the Chevelle. . .
Swapped a 402ci Big Block motor into the truck. I got everything from a donor truck. It includes the correct big block swap parts... Correct motor mounts/towers. Correct 4 row heavy duty radiator and fan shroud. It was also converted to HEI. The motor on had 60k original miles. The following is a list of new parts:
New Aluminum Water Pump
New Aluminum Timing Cover
New Cloys HD Timing Chain
New Oil Pan w/ 1 Piece Gasket
New Rear Main Seal
New Intake & Exhaust Gaskets
All New Grade 8 Bolts
New Motor Mounts
New Trans Mount
New Hoses
The truck has a complete new front suspension rebuild. All new MOOG parts, not cheap Chinese parts. (I thought I was going to keep the truck) I also upgraded to 1/2" bolts on the lower control arms. The drop is 4" in the front and 6" in the rear and it was done correctly, not just torching the springs. The following is a list of what has been done to the suspension and drive train.
Drop Spindles
Drop Springs (Front)
Complete Front End Rebuild
Custom Front Swaybar Mounts
Poly Swaybar Bushings
Quick Ratio Steering Box
Drop Springs (Rear)
Super Track Bar (Rear)
Rear Shock Relocation Kit
Custom 1 Piece Driveshaft
New U-joints
The truck is running on 17" Impalla SS wheels with 275/55/17 tires. The truck handles great, corners flat and the bucket seats help hold you in place over the stock bench.They are black Power Leather Seats out of a Chrysler 300M. Not shown is the first pics is a NEW black carpet...
The transmissnion is a TH350. Its the original trans that was behind the 307ci small block that was originally in the truck. While it moves the truck it will not withstand the torque the big block can put out.
I have collected a few other miscleanious parts that will be included with the truck. New glove box liner, pair of window regulators, misc small parts...
If interested please email me with a phone number to discuss the truck in detail. NO TRADES. If you're local I can usually show the truck on in the afternoons. I work nights.
I have a clear title ...
Like everyone else who builds something.. I have more then what I'm asking into it...
Interior was redone. New Carpet, padding and sound deadener. New custom made leather coverd kick panels. Has center console to match the bucket seats. Just put a new Edelbrock on it to replace the worn out quadra-junk. I have some cast aluminim valve covers, they are black with bowtie and lines that are not actually on there yet. It has a Zoops ball milled air cleaner as well.... Was originally looking for $8750 ...
Looking for $7750. . . need to purchase my crate LSx for the Chevelle...
Rich
Las Vegas
1969 Camaro * in hiberation ~
Old 12-31-2008, 05:08 AM
Interior Pics. Non AC truck.
Rich
Las Vegas
