Old 10-30-2008, 07:23 PM
Default G Bar, Air Bar, and Prodigy Bar tailpipes are here!
As seen on Larry’s MotiV8tr!
Prodigy Customs 2 ½” stainless pre bent tailpipes for G Bar, Air Bar and Prodigy Bar are here and in stock. These Mandrel bent tail pipes solve the fabricated tailpipe issue associated with these popular suspension systems. The tailpipes will fit any exhaust system with 2 ½” outlets (2 ½” pipes for 3” muffler oulet are also available) as long as the system has 12” to 14” center to center muffler outlets in the common dual muffler location. Most offset in / center out mufflers fall in this 12” to 14” center to center range.
These tailpipes are designed to work with “notched” tanks like Ricks or a notched factory tank. Basically any dog eared tank will work. And clear with plenty of room coil over and Shockwave applications.
Tailpipes are $450 a pair, and available now. Yeah, that is pricey, but all the cost is in the multiple bends and stainless material. Still much cheaper then fabricated tailpipes and a very quick install, and they fit perfect.
We also can combine these tailpipes with a Magnaflow 2 ½” or 3” exhaust systems we have in stock. 2 ½” system are only $500, 3” systems are only $650, Add tailpipes for $450 and your set.
The big myth:
Lots of people think you need 3” exhaust systems for 500HP or more. Experts will tell you that over 500HP you should run 3” to the mufflers. After the muffler the exhaust is pretty much done and 2 ½” is just fine. 2 1/2” tailpipes are good for horsepower up to 700HP with 3” Primaries and 2 ½” tailpipes. Full 2 ½” systems are good up to 500HP.
To order, call four zero seven 832 1824 or email [email protected]
Frank Serafine
Old 10-30-2008, 07:48 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Are you going to be doing from the Headers back? At least the cross over?
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
Old 10-30-2008, 08:28 PM
Yup, That is Magna flow and our tailpipes right there. A 2 1/2" system would be perfect on your car. We finished a LS6 Convertible this week with a 2 1/2" Magna flow and our tailpipes also. I will get you a sound clip and pictures
Frank Serafine
Old 10-30-2008, 08:32 PM
BBC69Camaro's Avatar
Hey Frank I know mentioned at one time about a 3" version, was that still on the table?
Thanks!
Old 10-30-2008, 08:50 PM
I think no 3", just to tight.
Frank Serafine
Old 10-31-2008, 09:12 AM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default "Quiet" Mufflers?
Which Magnaflow mufflers did Larry use? I like "quiet" too...
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 10-31-2008, 11:36 AM
Here Mark is the 2 1/2" Magnaflow system with the template tailpipes on a LS6 / T56 convertible.
Frank Serafine
Old 10-31-2008, 02:16 PM
Jr's Avatar
Jr Jr is offline
Frank,
Nice product!
What sub frame connectors did you use? Why didn't you run the dse connectors?
Thanks Frank.
Old 10-31-2008, 03:17 PM
On Larrys MotiV8tr they are DSE frame connectors. The convertible came in with Global West, YUCK! Hotchkis is way better for under the car frame connectors.
Frank Serafine
Old 10-31-2008, 09:59 PM
bigtyme1's Avatar
Perfect Frank, will talk at SEMA. What's the leed time?
69 RS Ragtop
[email protected]
