Old 04-12-2008, 11:22 AM
Tim Baillie's Avatar
Tim Baillie Tim Baillie is offline
Default Black braided AC line ?
Does anyone know who makes a black braid (metal or nylon) that will work with the high PSI of AC ?
I really want to use all the same line under the hood and would prefer black over the stainless........
Also, black AC fittings ? Only found the Aeroquip chrome ones......
www.hotrodderjournal.com
Old 04-12-2008, 11:45 AM
rjsjea's Avatar
rjsjea rjsjea is offline
Russell makes these
RobS
71 Demon, AlterK - 4 link GenIII hemi conversion
66 Rambler Classic Wagon, LS conversion -Scott's IFS/4bar-bagged
Old 04-12-2008, 12:13 PM
Will that handle over 350PSI ?
Everything I found in the Russell catalog was only rated to 350PSI....
Old 04-12-2008, 12:15 PM
rjsjea's Avatar
Not sure.....catalog is in the shop.
RobS
Old 04-12-2008, 12:56 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
To jump on...
What about some black ps hoses also? All I can find is nasty blue.
Old 04-12-2008, 04:31 PM
surreyboy
Guest
Posts: n/a
aeroquip makes a like called aqp higher pressure hose, its cloth braided, but its a dark blue.you could always use normal s/s braid and cover it with woven black sleeving and shrink wrap it by the connectors if you cant find black.
Old 04-13-2008, 07:26 PM
bentfab's Avatar
bentfab bentfab is offline
Hello all,
This is finally my first time posting. I've seen a couple posts on plumbing issuse recently. Plumbing is my main specialty. A/C lines are a touchy subject. What i've found to be the best is just use your typical connections from any of the aftermarket a/c companys. Take alittle time and lay thinks out as far as position and angles go assemble the ends and take them to a local shop or ship them and get the ends crimped. Blacking the ends out is my prefurred method and have found out the best way is to tape the hose off at the ends plug or cap the ends and sand blast off the gold erdit finish. Then paint it with SEM satin black bumper paint. If done properly this stuff sticks like nobuddys buisness. The other types of hose you are talking about aren't desined for a/c because it will bleed throught the hose. The areoquip hose is the ownly hose in the buisness designed for a/c. The teflon line used in the hydroboost systems appear to be the same but will also bleed through like the other hoses and also there ends in my opinion are very ugly!! So your best suited useing the orignal style a/c ends. Tried and true and alittle patience will always look the best. Check out my web site and look at the chevelle pics in the gallery and tell me what you guys thinkl of the a/c lines. I also just put on a hydroboost and used shrink tubing over the lines because I also wanted the black look.
www.bentcustomandperformance.com
Old 04-13-2008, 07:48 PM
rjsjea's Avatar
Originally Posted by bentfab View Post
Hello all,
WAy clean plumbing............looks good
RobS
Old 04-13-2008, 08:21 PM
bentfab's Avatar
Thank you!!!!
Old 04-13-2008, 08:55 PM
ironworks's Avatar
I'm sure we could all pick up many useful tips and tricks from Mark. He does plumbing thing like a true craftsman.
