Old 03-22-2008, 11:23 PM
evilzee28 evilzee28 is offline
Default hideaway headlights
Looking at a lot of the Camaros on this site very few people seem to run the RS hideaway headlight option. Is this due to the additional cost/work involved or the fact that people just don't like them. It's time for me to decide which way I'm going to go with this on my '69, as I have both the standard & RS set up, but just can't make up my mind. Your thoughts please.
Old 03-22-2008, 11:30 PM
jannes_z-28's Avatar
Personally I prefer the standard grille over the RS.
One problem with the RS is the vacuum dooractuators. There is a lot of stuff that will be needed for the vacuum to work.
If you'll go with the RS there are electric actuators you can use. The kits that are around uses linear motors. It is quite easy to build such a kit yourself, linear motors can be found in most electronic warehouses.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 03-23-2008, 05:42 AM
bill amsley's Avatar
bill amsley bill amsley is offline
there both sharp, but i think that the 69 rs front is one of the sharpest grille headlamp combos ever. be sure to check out the detroit speed electric motor conversion.(worth every penny in saved headaches) bill
Old 03-23-2008, 06:03 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
I had the standard set up on my 67 and have converted it to the RS. I used electric motors and it wasn't to hard to do. I would recommend the DSE motors.
Curtis
Old 03-23-2008, 08:33 AM
It's a decision only you can make. I like both personally. The reason I picked standard is, I think it's a more muscular look on a 69. On the 67-68 not so much.
Old 03-23-2008, 01:56 PM
class67's Avatar
class67 class67 is offline
I like the RS front end myself
of course...I may be a little biased
Steve
67 Camaro RS
66 Chevelle (in progress)
Old 03-23-2008, 02:37 PM
camcojb camcojb is offline
I think the RS front end on the 69 is the best look possible. I also would recommend the DSE motor kit, eliminates the undependable vacuum setup.
Old 03-23-2008, 04:01 PM
Lateral-g Moderator
I would agree with that.
Old 03-23-2008, 04:52 PM
skatinjay27's Avatar
agreed also...they both look great BUT a 69 rs front
AJ
Old 03-23-2008, 08:34 PM
awr68's Avatar
awr68 awr68 is offline
I go both ways...we're still talking headlights right? Ok, good!
Will you be using an intercooler...sometimes that can be an issue.
I think it depends on the rest of the car/trim really.
Tony
'68 Camaro
