Old 02-03-2008, 08:16 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Default Machined Stainless Steel hardware from Ring Brothers
When I saw these on the shelf at Ring Brothers, I had to have a few for my car. It's these little details that make all the difference. I picked up just enough to replace the fasteners that you could see under the hood.
My LS7 69 Camaro
Old 02-03-2008, 08:37 PM
camcojb camcojb is offline
yep, I'll be calling Mike for a set for Mali2ude, those are very trick.
Old 02-03-2008, 08:48 PM
mazspeed's Avatar
mazspeed mazspeed is offline
They finally have those out now??? How much for the camaro, and are they car specific?
Old 02-03-2008, 09:01 PM
XcYZ's Avatar
Yep, they're available now. They had a big assortment. You can order as many of any size that you'd like. I just got a few in 5/16" and 3/8". Not sure about a kit, but that would be a very good question to ask them when you call.
My LS7 69 Camaro
Old 02-03-2008, 09:04 PM
mazspeed's Avatar
That's awesome Scott, thanks for the info. Ill spend my lunch money on them.
Old 02-03-2008, 09:06 PM
eville's Avatar
eville eville is offline
Woah, I need some of those. Any werd on pricing?
Steve
'68 Camaro - 355", TKO600, SpeedTech Arms, ATS-AFX Spindles, Hotchkis Springs, Forgeline Wheels, C5 Brakes (Kore3), Holley Terminator EFI
Check it out Here
Old 02-03-2008, 09:38 PM
Blown353 Blown353 is offline
Hmmmm... I wonder if I could convince my CNC lathe guy at work that I need about 400 of those for "tooling."
1969 Chevelle
Old 02-03-2008, 10:12 PM
James OLC's Avatar
When i talked to them about what we needed for the OLC project they didn't have a kit but did have 1/4", 5/16", 3/8" and i think a metric size or two. They are absolutely increadible pieces.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-04-2008, 07:24 AM
XcYZ's Avatar
I should note that they are transitioning to a new website and their e-mail isn't working just yet. Just give them a call at 608-588-7399.
My LS7 69 Camaro
Old 02-04-2008, 07:51 AM
Steve1968LS2's Avatar
That's a lot like what I use except the washers are "deeper". Very nice. What do the back sides look like?
The perfect design would have a small raised disc on the back to help paint deformation remain unseen. Mine are flat on the back.
Also, what is the rough cost per a washer?
They sure make sweet stuff.
