Old 01-13-2008, 07:53 PM
Young Gun Young Gun is offline
Default 1999 Ducati 748 Mono Posto (Low Miles!)
As the title states I have a 1999 Ducati 748 Monoposto superbike. This bike is absolutely gorgeous and a blast to drive errr ride. The problem is that I have suffered numerous concussions lately and riding a motorcycle probably is not the best thing to be doing in hopes of preventing any future concussions. First of all the bike has less than 3500 miles on it, yes that is right, thirty-five hundred miles, three thousand five hundred miles, however you choose to read it. The bike is located in Houston Texas, so if anybody is local they are more than welcome to check the bike out. I am asking 7.5k for lat-g members, I am asking more on the local craigslist. The bike is in immaculate condition, NEVER been laid down. Specs on the bike are below and pictures follow that!
DIMENSIONS & WEIGHT
Overall Length 2030 mm / 80 in.
Overall Width 780 mm / 30.7 in.
Overall Height 1080 mm / 42.5 in.
Seat Height 790 mm / 31.1 in.
Wheelbase 1410 mm / 55.5 in.
Dry Weight 196 kg / 432 lbs. (monoposto)
Fuel Tank Capacity 17.0 L / 4.6 gal.
ENGINE
4 stroke 90 degree V-Twin
Total Displacement 748 ccBore / stroke88 mm x 61.5 mm
Compression Ratio11.5 : 1
Crank Horsepower 97 HP @ 11000 RPM
Cooling System Liquid cooling
Fuel System Marelli electronic injection; 1 injector per cylinderValve SystemDOHC, 4 valves per cylinder with toothed belt Desmodromic control
TRANSMISSION
6 speed
Clutch Dry, multi-plate, hydraulic control
FRAMEALS 450 tubular steel alloy trestle
Rake Adjustable for 2 positions; 23° 30' - 24° 30' Trail Coincides with rake; 91-97 mm / 3.6 - 3.8 in.
SUSPENSION
Front Suspension Inverted type, 43 mm diameter stanchions,
fully adjustable Rear Suspension Progressive linkage with adjustable monoshock
BRAKES
Front BrakeDual 320 mm stainless steel floating rotors
Rear BrakeFixed 220 mm rotor with floating caliper
WHEELS & TIRES
Front Wheel 3 spoke light alloy wheel 3.50 x 17
Front Tire 120/70ZR17
Rear Wheel 3 spoke light alloy wheel 5.50 x 17
Rear Tire 180/55ZR17
Please email me at [email protected] if you have any questions about the bike!
Oh yah and I am willing to trade...not sure what but I dont want to have to do any body work on it, if it comes with a strait six and a powerglide then thats perfect, looking for a work in progress essentially, I just dont want to have to do body work on it. Thanks
