twin turbo lt1 over 1100 rwhp capable the engine is brand new here are the specs
the motor was built by B&B performance
displacement is 400 ci b=4.051 s= 3.875
callies racemaster crank
oliver billet 6 in rods
custom ross pistons -23 cc coated
billet maincaps
block has been O-ringed
AFR 215 Raised runner heads (best lt1 head you can get) ported by B&B they flow into the 330s and the buyer can have all the flow specs.
72cc chambers on the heads
cr of 8.8:1
copper head gasket
intake valve 2.125
exhst valve 1.625
valves are ferrea super alloy
comp 943-16 pacalloy (sp?) springs (cryogenicly frozen)
custom billet sollid roller cam from cam motions (specs to buyer)
crower solid roller loffset lifters
crower offset stainless shaftmount rockers
intake is a victor jr converted for fuel inj. fuel rails are from wilson manifolds.
polydyne coatings: piston tops, comb chambers. exhst ports, valve faces, bearings
custom made sheetmetal valve covers
very nice looking flexible oilpan dipstick tube (dont rememebr the brand, im sure if your interested in the motor your not to concerned about the brand of the dipstick though lol)
moroso oil pump
canton 7 qt pan
wilson 105mm tb
wilson 90 degree elbow
wilson fuel rails
shortblock $4450
top end $5500
custom alum front motor plate
turbosmart progate blow off $250.00
two precision t67 turbos they have around 1000 miles on them no shaft play $1250.00
2 air to air intercoolers each good for 750hp $420.00 each
2 autometer phantom pyrometers with probe kit $205.00 each
2 starter down pipes with 02 and egt bungs in them.
updated list make me an offer
thanks
