Old 08-20-2018, 10:58 AM
Nice work, dude! Dig the three-link and stock car parts! Methinks one of the next things that will really annoy you on the autocross will be the whack angles that strut front end provides in relation to camber. You can just make your own SLA later . . .
We seem to be operating with a similar cycle: Thrash car, rip apart and drastically change, then repeat.
Old 08-20-2018, 11:29 AM
Merritt5 Merritt5 is offline
That looks like NCM... Fun place to race if it is.
Can't wait to hear more feedback on how you like the 3 link with the panhard bar. Nice work on the homebuilt transformation...
Thank you! NCM it is! Haven't got the chance to run on the track, but I do love running autocross up there.
Thank you and a SLA front is what I would like to do. Griggs has a bracket that will bolt to the front spindle, to allow an upper ball joint to attach.
Build as you go! That's what I try to stick to.
1993 Fox Body...its in the works
https://lateral-g.net/forums/showthread.php4?t=54321
1972 Nova...OUT OF THE BARN!!!!!
IG:@kdmerritt5 for more
Old 08-20-2018, 04:00 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Looking good man. I got rid of the black fox a year ago or so but I'm getting my other one put together now. I needed some more motivation so it's nice to see some posts from you!
The Following User Says Thank You to Josh@Ridetech For This Useful Post:
Merritt5 (08-20-2018)
  #44
Old 08-20-2018, 05:34 PM
If you do your own SLA this is the "budget" drop spindle I've seen people use on homebrew Fox SLA's that is priced in between a $50 SN95 spindle and the $2500-3000 Griggs and Cortex spindles.
https://www.racecraft.com/2-drop-spindles-c-280/
Old 08-20-2018, 05:59 PM
I do not. I'll have to get under the car.
They aren't pretty, but I tried to put as much heat as I could to get good penetration.
I checked all the welds for cracks, this past weekend, and everything seems to be holding up so far.
Good deal. Glad you're keeping an eye on them. From what little I can see, I'd say move in closer with the gun to help get the heat into the metal.
Old 08-21-2018, 07:32 AM
Hmm...I'll have to check those out.
Thank you, sir. I'll have do that next time.
Welding is something I can definitely improve in, so I'm always open to critiques.
Old 08-22-2018, 07:09 AM
I have a brand new LS K member with arms if you need one, change of plans.
Old 09-17-2018, 10:52 AM
Got some new wheels! 18x10.5 on all corners.
The fronts were rubbing at full lock and with a spacer (can't remember the spacer thickness off the top of my head) and I didn't have enough wheel stud to feel safe.
So longer wheel studs are in the future.
Put the old wheels back on and hit the local autocross and I was able to get a shot of the rear suspension during one of my runs. Check it out!
Old 09-17-2018, 11:53 AM
New wheels look great.
The Following User Says Thank You to Flash68 For This Useful Post:
Merritt5 (09-17-2018)
  #50
Old 09-17-2018, 09:28 PM
Thanks! I'm really digging them
Sent from my SM-G930V using Tapatalk
