Old 03-29-2016, 10:16 PM
Hugger67RSSS's Avatar
Hugger67RSSS Hugger67RSSS is offline
Originally Posted by Z06vette View Post
I have been eyeing these up. Has anyone tried them?
http://www.speed-engineering.com/ls-...6-engines.html
Trying to get my buddy to give them a shot, as he has dynatechs as well with poor ground clearance. Shimming the tailshaft would help a ton, but he's running a t56 and it hits the tunnel. In the short term we are going to cut the collectors off the dynatechs & run a slip fit collector with a thin style band clamp.
I have those exact headers going into a 66 GMC truck. They appear to be pretty well made. Welds look good and flanges are thick. I've had them bolted up and they align with all the bolts fine. I know they are knock-offs but was worth a try. I'll start a thread on the truck in a few days and take some pictures of them.
Aarik
68 Camaro 6.0/T56, Jake's Rod Shop C6 Subframe, JRS Torque Arm, Ridetech TQ Coilovers
Old 03-30-2016, 07:45 AM
toddoky toddoky is offline
Originally Posted by Vega$69 View Post
This the problem. On T56 tranny installs the tunnel needs to be cut to get proper driveline angle which also brings the header collectors level with the subframe and achieves more ground clearance. Also keeps the engine level in the engine bay and the rear of the engine parallel to the firewall and puts less stress on the motor mounts.
We have dynatechs on a 69 lowered 2" on Hotchkiss springs. Clearance work ok. I ran Hooker Supercomps on 2 cars and they tuck up nicely higher then the FBody oil pan.
Ya, he needs to raise the tunnel. We'll do it eventually. I raised mine last winter during a motor & subframe swap with the alston chassisworks cap. For now we'll delete the collectors flanges to the slip fit style. There's only a few scrapes on the header tubes themselves, but the collectors are ground down a bit. Its still going to scrape, but at least it will be on a flat surfaces vs a vertical one.
Hey guys, just as a side-not to this thread, you only have to raise the tunnel on a 1st-gen LS/T56 swap to be able to achieve desirable U-joint working angles if you are using the stock frame stands and swap plates to mount the engine. The Hooker 1st gen LS engine mounting brackets and T56 crossmember mount the engine and transmission lower in the chassis than is possible using the frame stand/swap plate mounting method and requires no tunnel modifications to install either a 4th-gen F-body T56 or T56 Magnum transmission in the car while achieving optimized U-joint angles. The Hooker Blackheart 1st-gen headers are designed around this mounting geometry and provide tight tucked ground clearance.
Old 03-30-2016, 08:29 AM
im4u2nvss im4u2nvss is offline
Quick queston toddoky. Do you know if 1/2 height body mounts will still clear with the Hooker swap setup? Or would tunnel need to be raised to clear F-body T56(may be getting greedy but wanted to ask).
Old 03-30-2016, 09:39 AM
No, the Hooker 1st-gen LS swap system is not compatible with the use of 1/2-height body mounts. This is primarily due to the way the crossmember is designed to extend up into the formed pockets in the floor to maximize exhaust system ground clearance (photo attached), which leaves only about 1/8" between the top of the crossmember and the floor pocket sheet metal. It would take quite a bit of sheet metal work to make everything play nice together if you wanted to use 1/2 height body mounts.[IMG][/IMG]
Old 03-30-2016, 09:47 AM
n77nxc's Avatar
n77nxc n77nxc is offline
That crossmember is next on my list. My BMR crossmember is now limiting how far up I can place the downpipes.
1967 Camaro - Project "Resale Red" - Sold to 175RGR
Old 03-30-2016, 10:01 AM
It's a great piece, but be advised that it will only work for you if you are using the Hooker 1st-gen engine brackets, or others that provide the same fore/aft engine placement. If you are using common 1" set-back plates, the mount on your transmission will extend too far back and the case of the T56 will crash into the crossbar...it's a mess of a situation.
Old 03-30-2016, 10:09 AM
n77nxc's Avatar
Hmmm, I'll have to investigate a bit. I'm running a 4L60E.
Solid info though! Thanks!
Old 03-30-2016, 10:16 AM
There is a specific Hooker crossmember for the 4L60, but you would suffer the same grief if using the frame stand/1" set-back swap plate set-up.
Old 03-30-2016, 11:29 AM
Thanks toddoky.
Old 03-30-2016, 11:47 AM
Here's a bottom-up view of the Hooker 1st-gen LS/4L60 set-up. You can see in the photo that there's little room for deviation from the designed fore/aft engine/transmission location that is designed into the Hooker 12618HKR engine brackets. [IMG][/IMG]
