Originally Posted by Mathi
Yeah, and to be honest, price is okay... If you see what you get is it almost everything for the conversion. But on the other way, it's true, I don't know where the miles were spent...
I guess I'm going to ask the seller some details about the engine...
how much difference of weight is it with the aluminium engine from newer models?
Regards
The aluminum engines are a little over 100 lbs lighter than their iron block equivalents. So you are looking at around 570lbs instead of 670lbs (shipping weight on the iron block crate engines was about 720lbs).
You do realize by the time you get done changing the fuel system, replumbing, changing the radiator, building and routing an intercooler, building a custom hood, and making a front drive system to work, not to mention all the little stuff like changing front springs, etc that you will have 40-50k USD in the car, right?
If you are really dead set on this, I may be able to get you a 2011 aluminum block engine with less than a hundred miles on it.
