Hey guys!
For some reason my notification turned off (or maybe I didn't set it up??!???
Thanks for the good information. It would be great to maybe put together a list of LS2 specs from everyone. Then over time a User could sort of pick what they were looking for as far as end result and then copy the build...
Here's mine:
Intended Use: Street/track, Pro-Touring build
Engine: 2007 LS2 (TBSS motor)
Crank: Stock
Oilpan: F-Body (Pace Perf: PAC-8771)
Heads: L92 (Scoggin Dickey: SD8801-1)
Intake: TBD - LS6 or F.A.S.T or Holley LS 92mm High Ram
Compression: ~ Stock 10.6/1
Cam Specs: TBD
Idle Quality/RPM: Lumpy!!
Fuel System: TBD : Aeromotive Stealth A1000 cell or similar build
Max HP: TBD : aiming for 500 range
Max Tq: TBD : aiming for 500 range
