I will be replacing the floorpan and the trunk pan on my 68 Camaro. My truck pan has a lot of pin holes in the center and crunched in the driver side which is why it will be replaced, the floor is flinstone status. I also need toeboards.
My question is one-piece floor pan is the best? or which companies should I avoid?
I did a lot of searching and found more than plenty of information on how to do the install, now I just need to know where to buy
I have used a few of the dynacorn 1-piece floors and fit has always been good. Bel-air Bobs has been a good source for alot of the floorpans,side cowls, etc, I've needed for the camaro's projects we have done. Joe
I went with a full floor from Classic Industries. It looks good and my builder likes it but it's not in the car at the moment so I don't know what the fitment is.
Other guys on here know more about this then I do so hopefully they will chime in and help you out.
Dynacorn here. Fit was good considering the tolerances of these cars. Not sure if others like Goodmark are actually the same source panel from overseas.
I used the Goodmark piece and it went in well with just a little stretching. I read about a one piece full floor, trunk and frame rails from Bel Air Bob's over on Camaros.net that sounded interesting but it was high $$$$.
