Old 06-29-2010, 07:34 PM
frankv11's Avatar
frankv11 frankv11 is offline
Default 69 camaro how wide can I go on tires w dse subframe
working on a 69 planning on going with dse subframe what is the widest tire I can get in there. can I do 295/30/18
Old 06-29-2010, 07:46 PM
markd's Avatar
markd markd is offline
Here is the info from the DSE website:
Q: What are the largest size tires I can fit underneath a first generation Camaro?
A: With the stock suspension, the largest front tire is a P245/45R17 on an 8 inch rim or a P245/45R16 on an 8 inch rim. Areas to watch for signs of tire/wheel contact are; tire inner sidewall to subframe under full lock steering, wheel inner to stock upper control arm during full lock steering, tire outer sidewall to fender lip especially on 1969 models. The largest rear tire is a P275/40R17 on a 9.5 inch rim.
Hope this helps with your decision
Mark
Project 69 Camaro: DSE mini tubs, Chassisworks G-Bar and FAB-9 rear suspension, Chassisworks front sub-frame, 14” Wilwood brakes with 6 piston red calipers, 18" Fesler 905 Wheels, Fesler Billet, ISIS multiplier system, Vintage Air, Prodigy Cool Package, Ricks Tank, Turnkey LS3, 4L65e transmission and a lot of other cool stuff!
More pictures: http://camaro69vn10.com The Website is finally Updated!
https://lateral-g.net/forums/showthread.php4?t=13756
Old 06-29-2010, 07:50 PM
frankv11's Avatar
I know I have heard that some people are running 10" wide wheel im just not sure if it was 275 or 295 tire.
or am I dreaming?
Old 06-29-2010, 08:10 PM
275 with lock to lock steering.
Old 06-30-2010, 05:46 AM
275/35/18 on a 10" rim with a 6.125 BS is what we put on them.
Frank Serafine
Old 06-30-2010, 06:41 AM
frankv11's Avatar
thanks guys for all the help
