Old 01-21-2012, 09:43 PM
Lenie's Avatar
Lenie Lenie is offline
Default Laser jet? Washington area, anyone.
I've got a couple of aluminum pieces about .080" thick I'd like to laser cut words completely through, do you know anyone in Washington that does this?
Lenie
Old 01-21-2012, 09:53 PM
DENTGUY's Avatar
DENTGUY DENTGUY is offline
Lenie,
Can they be water jet cut? If so, what about Flow Engineering in Kent?
03 SS Silverado 12.2 @ 108
07 TBSS- Work truck
56 Belair-Money Pit
Old 01-21-2012, 10:03 PM
Lenie's Avatar
Originally Posted by DENTGUY View Post
Lenie,
If it will give me a nice clean cut it'll work. I'm just making some valve cover covers. once cut I'm going to paint or powder coat them. Thanks for the heads up, I'll check into them. Have you used them in the past?
Thanks again.
Lenie
Old 01-21-2012, 10:06 PM
DENTGUY's Avatar
I havent used them, but I know they have been around quite a while. Never heard anything bad. What part of Wa are you in? Actually I have a shop up in Bellevue that has a water jet also. HMM, I can get ahold of my guy there and see what they can do.
07 TBSS- Work truck
56 Belair-Money Pit
Old 01-21-2012, 10:11 PM
Lenie's Avatar
I'm in Port Orchard but my son lives in Kirkland and I'm there quite a bit. PM me your number and I'll give you a call here soon as I'm currently working them hoping to finish soon and would love to give you my business.
Lenie
Old 01-22-2012, 07:49 AM
MODO Innovations's Avatar
Thanks again.
The waterjet will give you a finish on the edge of the part similar to a sandblasted part. The edge can be easily smoothed out with a scotch brite wheel or file.
Shannon
Modo Innovations
940-391-9002
Old 01-22-2012, 08:04 AM
Lenie -- Just bring 'em over here -- you can freehand 'em with the plasma... then walk a few feet to the BurrKing 760 and grind on 'em for a while... then I'll hand you a angle grinder - and you can work your way down from 60 to 120... and finally hand sand them - then walk over to the Baldor and start buffing...
Shouldn't take more than a day or two....
EEEEEEEEEEHHHHHHHHHHHAAAAAAAAAA
Old 01-22-2012, 12:27 PM
DENTGUY's Avatar
Lenie,
My post read a little off. Its not my shop, its a shop I do work for. Ill get ahold of the guy I know there and see if thats something they want to tackle. I'm pretty sure it would be an easy deal. Unless of course you want Greg to "Git Sum" with his plasma cutter
Ill get in touch with ya....
07 TBSS- Work truck
56 Belair-Money Pit
Old 01-22-2012, 01:34 PM
96z28ss's Avatar
96z28ss 96z28ss is offline
Do you have a cad file and font type picked out?
If you want a super clean edge that doesn't require any work especially in the lettering area then Laser is the only way to go.
I use a local company here in Portland. They are fast and cheap.
If you don't mind the shipping.
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
Old 01-22-2012, 04:02 PM
Lenie's Avatar
Thanks for the heads up Shannon
GregWeld Lenie -- Just bring 'em over here -- you can freehand 'em with the plasma... then walk a few feet to the BurrKing 760 and grind on 'em for a while... then I'll hand you a angle grinder - and you can work your way down from 60 to 120... and finally hand sand them - then walk over to the Baldor and start buffing...
Maybe we'll just kick back, drink a cool iced tea and wait for the little brown truck. Don't want to get my fingernails dirty ya know
Lenie
