Hi everyone,
I'm new to the forums here and have some parts for sale.
Here's some info:
-The trans is a 2008 model TR6060
-I also have a new Mopar dual disc clutch and flywheel setup
-The dual disc setup is made as a kit to be bundled with this trans
-The kit is made for 2003-2006 8.3L Vipers
-A bolt in trans crossmember comes with the trans
-Also have a new aluminum driveshaft with yoke and u-joints for the 03-06 install
-There is no hydraulic throw-out bearing in the kit
The dual disc clutch is part # P5155122
The trans is part # P5155123
I'll bundle the driveshaft with the trans for $2,000. If you want the dual disc clutch with the trans I'll give you a deal on it. The dual disc clutch also fits new SRT8 flywheels. I'm located in Southwest Washington state.
I'm not sure what the gear ratios are. The trans is part of an upgrade kit from Mopar Performance (the part numbers are listed in the original post). I would imagine it uses the same ratios as the 08+ SRT10s.
Also, this is a brand new trans in the crate. It is not a pull out or junkyard piece. Mopar sponsored the drivetrain in my project vehicle and sent out several parts that I did not use.
