Go Back   Lateral-g Forums > Technical Discussions > EFI and Forced Induction
Old 04-14-2005, 04:14 PM
camcojb's Avatar
camcojb camcojb is offline
Default Dynoed my daily driver pickup
Dynoed again this morning. My last numbers were 560 rwhp and 597 rwtq with a built motor, heads, cams, KB, 100% stock exhaust, and 19 psi of boost. I have had a full exhaust in the past before this engine and was not happy with the noise. But after seeing my dyno numbers and the fact that it felt down on torque, I purchased a Dynatech LT set, twin cats, and Bassani BX cat-back. I also bought the Bassani baffles that go in the tips. My first surprise was that this LT setup was much quieter in the truck than the same basic setup I had earlier. There was one difference, the original setup used the stainless Bassani cat-back and I now am using the coated steel one. I am positive it's quieter, and I'm saying the steel unit transmits less noise to the interior than the stainless one.
To the numbers. With the LT's I couldn't get exactly 19 psi with the pulleys, it either made 18 or 20. So I did a pull at 18 psi with the LT's and made 590 rwhp and 635 rwtq. So a pound less boost made 30 rwhp and 28 rwtq more. This is my street tune with alky, 15 degrees of timing.
Then I pullied it for 21 peak boost. This was on race gas and 20 degrees of timing. It made 621 rwhp and 708 rwtq. I made one pull without the baffles and one pull with. It actually made more hp and torque with the baffles but it was so close it could just be in the dyno itself. The baffles are good for a little more noise reduction in the cab, and cost no power at the 600/700 level, so I will be running them all the time.
PAST CAR PROJECTS
Like Lateral-G on Facebook!
SPECIAL THANKS TO:
Old 04-14-2005, 04:31 PM
rwhite692's Avatar
rwhite692 rwhite692 is offline
Damn Jody that's awesome. I could get myself into real trouble if my daily driver carried such a big stick.
______________________________________________
1969 Camaro/ Tom Nelson TT 434 / Wayne Due C5 / DSE QLink / and a bunch of other stuff...
Project update thread here:
https://lateral-g.net/forums/showthread.php4?t=12743
My Lateral-G Page
My Shop Build:
http://www.garagejournal.com/forum/s...ad.php?t=16310
Old 04-14-2005, 04:34 PM
zbugger's Avatar
zbugger zbugger is offline
You're sick I tell you!! SICK!!!!!!
Although I guess it is more fun.
Old 04-14-2005, 05:19 PM
mdprovee's Avatar
mdprovee mdprovee is offline
WOW that much power for a daily driver. Incredible.
Mike
Old 04-14-2005, 05:25 PM
camcojb's Avatar
What's incredible is there's more in it. Most of the guys with a built motor like I have are running 24-26 psi on their race tune , I'm stopping at 21 psi (for now!). It's also only 330 cid, pretty small V8.
PAST CAR PROJECTS
SPECIAL THANKS TO:
Old 04-14-2005, 05:55 PM
907rs's Avatar
907rs 907rs is offline
Damn! Thats crazy, Jody. You'll have to take it to the track once to see what it'll run.
Bill
Old 04-14-2005, 06:16 PM
spaztikatik spaztikatik is offline
so, let me get this straight
your daily driver runs off alcohol
does that mean you could carry white lightning in the passenger seat and just pawn it off as gas?
honestly, your truck is a-w-e-s-o-m-e, even if it is a Ford
Old 04-14-2005, 06:39 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I can't believe how big those numbers are with only 15 degrees. Just how small is the chamber?
Congrats!
My LS7 69 Camaro
Old 04-14-2005, 07:23 PM
camcojb's Avatar
Bill,
There's guys in that power range running high 10's. My guess is low 11's with slicks.
PAST CAR PROJECTS
SPECIAL THANKS TO:
Old 04-14-2005, 07:24 PM
camcojb's Avatar
Congrats!
I have no idea! Stock WOT timing on these trucks is only 12 degrees. The modular motor design and overhead cams makes this one a learning experience for me. Best part is I tune it myself with a cool program that gives me control over the factory computer.
PAST CAR PROJECTS
SPECIAL THANKS TO:
