Old 02-15-2016, 11:27 AM
JsTA JsTA is offline
Originally Posted by GrannyNova View Post
The LS1 T56 is built stonger and better than the LT1.
I thought that was only for the 93 transmissions and 94+ was the same internally except for the differences for the throwout and such?
Old 02-15-2016, 06:13 PM
GrannyNova's Avatar
GrannyNova GrannyNova is offline
For what I read through out the run they was constantly updating it.
Old 02-16-2016, 11:46 AM
According to Borg Warner (later Tremec) both varieties were rated at 450 ftlbs of torque. While they most definitely will hold more, I don't think anything changed. According to what little I found the only major difference was in 98 it changed to Tremec as the manufacturer but nothing mechanically changed. There are later differences but fbodies never got them from the factory (different synchro design for the 01+ Z06 and first gen CTS-V and LS2 powered GTOs for example). I'd say an LT1 would do just fine and would be much easier to install.
Old 02-16-2016, 11:57 AM
flomofo flomofo is offline
Default ..
Maybe one of those new lightweight V6's out of a newer Camaro would bolt up....
Old 02-16-2016, 08:27 PM
GrannyNova's Avatar
It's what ever comes cheaper first.
Old 02-16-2016, 08:31 PM
GrannyNova's Avatar
I wouldn't mind the newer all aluminum Ecotec 3 4.3L V6, but it's just too technologically advance for me, but I got a plan for when I top out with the stock blocks to go to a Bowtie block and stroke it out to 5 liters.
The original V6 is out because of the I snapped a water pump bolt into the block and can't get it our so there is a 305 in the floor and I figure use it for a couple of years.
Old 02-17-2016, 04:11 PM
carkrazy1987's Avatar
carkrazy1987 carkrazy1987 is offline
i bolted a stock lt1 t56 to my 430hp small block in my 60 chevy truck, thats the reason why i brought it up, it was a direct install, the only thing i had to do was a cross member, and make a custom clutch line. and so far so good, and its been about 2 years now.
1960 Chevy C10 Apache
1969 Chevy Nova
2007 Chevy TBSS
Old 02-17-2016, 04:15 PM
pssst, also i would stay away from the new ecotec 3 4.3l, we've been having quite a few ummm.... fall apart... or make their own crankcase vents. give em some time to fix the bugs
1969 Chevy Nova
2007 Chevy TBSS
Old 02-17-2016, 10:02 PM
GrannyNova's Avatar
Thanks
Old 03-21-2016, 03:04 AM
GrannyNova's Avatar
Built a 305 small block with Lunati .471/.480 cam, 350 heads, 350 tbi, Texas Speed LT1 headers, Jet performance chip, and some Borland mufflers
