Old 11-11-2015, 01:18 PM
Nice looking car. The wait for the pictures was worth it.
Old 11-11-2015, 01:34 PM
64mali's Avatar
64mali 64mali is offline
Thanks waynieZ! I'm still working on getting photos into photo bucket but for the most part this is kinda where I started a few years back. I'll get more in and start showing the work I've been doing. It's definitiely not one of these high end bad ass builds but it will be a cool garage build budget pro touring car.
Old 11-11-2015, 08:26 PM
MOREHORSEPOWER's Avatar
MOREHORSEPOWER MOREHORSEPOWER is offline
I gave this one to my 17 year old son . Would love to hear your plans . This one will get a full SpeedTech Performance frame boxing with cross member as well as 4 corner coilovers A arms and some mor stuff from them . LS3 with a Richmond 5 speed and a Fab 9" rear.
Old 11-11-2015, 11:47 PM
Beautiful color, what is it ?
Old 11-12-2015, 08:57 AM
Evan Iroc-Z Evan Iroc-Z is offline
No problem. Glad I pointed it out, that's a good looking car you have.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 11-12-2015, 08:14 PM
64mali's Avatar
So is started the ol T56 swap. I wanted to try and keep the floor as original looking as I could on the top and bottom so I opted to section and raise the existing tunnel. Here's kinda how I did it
Old 11-12-2015, 08:20 PM
64mali's Avatar
Old 11-12-2015, 08:34 PM
64mali's Avatar
I created roughly 2" strips using the cuts as a template then tacked them in place. I rolled the floor slightly in some spots and tacked it all together essentially raising the trans 2"
Old 11-12-2015, 08:46 PM
64mali's Avatar
Then I had to relief cut the firewall and bring it up to the height of the tunnel. The end of the tunnel needed some work molding the old pieces and new pieces together
Old 11-12-2015, 08:59 PM
64mali's Avatar
I cleaned it all up and put a coat of primer before I welded up all the old holes in the floors. I welded in bucket seat brackets and prepped the floors for Por15. The florrs were all in all pretty clean. There was surface rust in all the standard spots but nothing went threw and they were all in all pretty solid
