I am now many months behind schedule. Work got busy and started other projects, blah blah.
But Ive now sourced the entire zr1 brake setup, ive bought a few more parts as well. I machined a small fixture to hold the c6 vette spindles in the mill so i can modify them for the 7deg taper i'll be using. Rear subframe is 100% done and getting laser cut now. Finishing up fixtures in solidworks this weekend so i can start building the control arms.
Trying to figure out what steering rack i want to run on this thing so i can start on the front crossmember and suspension brackets off the frame. But have no idea on what to use. Progress should hopefully pick back up though since ive finished all my small projects that i started the last few months.
Heres the subframe. Some sheetmetal is missing but its fully boxed in and should do the trick. I also made a jig that will slip over both frame rails and locate all the brackets, etc....
