Old 05-26-2016, 08:48 PM
Ken, are you taking the Nomad on Power Tour this year Or one of the others?
Old 05-26-2016, 08:59 PM
kwhizz's Avatar
kwhizz kwhizz is online now
Because they changed the dates this year .........We will miss the Power Tour due to other things going on........First time in 11 years.......
Old 05-26-2016, 09:02 PM
I'll make it one day........
Old 06-12-2016, 06:59 PM
kwhizz's Avatar
It's been a while , update........Pulera's got the paint mixed and matched.......as long as they got it that close I decided to have them fix the passenger side wheel well area.......there was a spot (very small) where there was a paint adhesion problem (small bubble)......not a rust issue at all....But......Like everything at Pulera's......they don't do anything unless they do it correctly.....so....Before and after pic's............Should get it back next week so I can get some miles on it.......
After
They also repainted the top of the fenders that had a bunch of paint chips that I put in while installing the core support
Almost there..........
Old 06-12-2016, 07:29 PM
PERFECT!
You so have it going on!! LOL
Old 06-12-2016, 07:52 PM
From here it looks like a perfect match, they do some nice paint work.
Old 07-05-2016, 07:03 AM
kwhizz's Avatar
Update.........The car is pretty much finished and we have taken it on a couple of short trips to check it out.......A couple of things needing improvement are getting rid of the rear leaf spring choppy ride (to be replaced with a 4 link Coil Over set-up) and the front seat.........We will be getting a split bench contoured foam seat and get it re-upholstered in original material to match......the stock seat is like sitting on a Park bench......LOL........Done but not "Done"......
Old 07-06-2016, 12:04 PM
1in1969 1in1969 is offline
Very nice Ken.
I was thinking with real estate it's location, location, location.....
with our cars it's refine, refine, refine!!
Shawn
Old 07-10-2016, 06:38 AM
kwhizz's Avatar
Update.........I ordered a Glide Engineering seat for the car........the stock seat is like sitting on a Park bench..........and after driving coil spring cars for a while, I forgot how bad leaf spring cars ride.........ordered a 4 link Coil-over set-up from RideTech...........which means I also had gas tank clearance issues..........a new Ricks Tank is on its way.......which means I have to remove the spare tire well...........LOL.......it never ends......but....in the end it will be a car with all the creature comforts of the other cars and the drivability to do Road Tours..........The A/C unit cools the car very well..........no Problems at all.....The lower control arm bushings on the front suspension were in pretty bad shape.....so , I bought new upper and lower tubular control arms and they will be installed next week............Never ends.........But.....I know where I want to end up........so......LOL.....
Old 07-20-2016, 09:01 PM
kwhizz's Avatar
The Car is at Frame-Up Wheelworks getting the triangulated 4 Bar set-up installed....along with the new tank and spare Tire storage well mod's.........Here are some pic's of the start of the process....
