Originally Posted by 72Z/28
Great build, can't wait to see it whe it is done.
I noticed you guys will be using the tanks inc fuel tank. Are you going to upgrade the tank with dual fuel pumps to cater the power the engine is going to produce.
Another question regarding the A/C compressor, did you have to notch the frame to have a lower mount A/C compressor??
Hi, Thanks!
We were originally going to be using the Tanks Inc. Fuel tank with the upgraded fuel pump, but it turns out, that it did not fit with our Detroit Speed Tubs.. We are now using a fabricated Ricks Tanks setup.
Also, We did not need to notch the frame, but then again.. We did fabricate our own A/C compressor bracket.
Hope this helps!
