Old 04-28-2016, 10:50 PM
67txcamaro 67txcamaro is offline
Default start all over
i thought i was going to be able to drive to a car show by the first week of june.
as we had the car run a lil longer with everything connected and it look we were on the right track
we noticed coolant under the car coming from both sides of the motor between the heads and the block. talk about a set back. i hope its something wrong with the gaskets or maybe something not major.
Old 04-29-2016, 11:10 AM
That sucks! I hope it's an easy fix. Good luck.
Old 05-16-2016, 02:07 PM
Efi69Cam Efi69Cam is offline
did you install the steam port plugs in the heads?
Old 05-18-2016, 01:10 PM
trymyz trymyz is offline
What year motor and heads? I believe the early style heads had a notch and can only use a particular gasket.
Old 06-01-2016, 10:22 PM
removed the heads and took to machine shop. the heads were warped all back together and ready for show. ported and polished while machine shop
