I was stewing about how I was going to get those dowel pins out without hurting that aluminum block. So I designed a dowel pin puller out of a piece of pipe, a grade 8 bolt, nut and two washers. With a little welding it worked great. Anybody that has a Shelby/Aluminum block take note. They were in there tight.
Centered the bell housing and welded the washers in place. Looks factory after I painted them, huh.
Ready to go. No. Wait. My pressure plate is a diaphragm, and the flywheel is designed to the long finger (or Ram) pressure plate. Well, after a long discussion with Keith Craft and Rob in Plano, we are making a change. Dual disc clutch setup. Clutch, pressure plate and flywheel all with be changed. So I just assembled what I could.
