Old 08-18-2017, 01:31 AM
Big_dime85 Big_dime85 is offline
man I love everything about this. thats a nice looking truck without being way too flashy. Guys who know what they are looking at will definitely dig this!
Old 08-18-2017, 04:04 AM
GrannyNova's Avatar
GrannyNova GrannyNova is offline
Thanks, it a bit of a unloved body style especially in the aftermarket but I think it's almost as good looking as the 1967-72 C10s.
I went to Roadkill Zip-Tie Drags in Memphis in July and they scoffed at it because these trucks aren't really hot rodded much. And after that I almost took down a 2013 Camaro SS in the process.
1991 Cheyenne Super LT1/T56
1978 Nova four door
1970 C10 501ci. Long bed
1991 Oldsmobile Custom Cruiser
Old 08-18-2017, 03:42 PM
Looking good. Congrats on nearing completion.
Don't worry about what others think of your choice for hotrod. It wasn't that long ago that these trucks were hot rodded and slammed to the ground. They look great.
Old 09-03-2017, 01:17 AM
GrannyNova's Avatar
Well completion has to wait as my cheap clutch purchase bit me and now I'm going to fix it with more power. I picked up a 93 Corvette LT1 for $500 with nearly everything on it including the OBD1 ECM and harness and motor mounts.
The is a plan is cam it, 500hp clutch kit (don't know what company yet), bigger valves and gasket matching, 52mm TB, and the other bolt ons that I already have.
1978 Nova four door
Old 09-03-2017, 10:19 AM
Unless you plan to go twin disc from McLeod, your clutch choices are limited. I'm running the McLeod Street Extreme disc with an AC Delco pressure plate. Works great behind the 383.
Good luck.
Old 09-03-2017, 11:59 AM
GrannyNova's Avatar
Good luck.
I'm looking at Spec stage 2 kit or a McLeod Super Street clutch. I leaning more to the McLeod even though it costs more.
1978 Nova four door
Old 02-11-2018, 12:40 AM
GrannyNova's Avatar
The clutch got done a while ago, bought a McLeod Street Pro clutch and after a couple of thousand miles and runs like a dream.
Installed a Belltech 1⅜in front sway bar.Name:  IMG_20180211_003649.jpg
1978 Nova four door
Old 06-11-2018, 04:31 AM
GrannyNova's Avatar
Pulled the cam for a Lunati Voodoo 219/227 cam. Also swapping out any visible bolt with ARP stainless steel 12 point bolts.
Then got the heads and intake off and sent to Texas for porting. Looking to max out the stock bottom end before going to a 377ci short block.
1978 Nova four door
