LS1/LS6 ready to go engine.
2004 LS1 crate engine, brand new, but outside any warranties so was modified. Has about 3,000 miles on it.
-LS6 z06 newer block 04+
-FAST 102 intake
-FI connection 36lb injectors
-FAST 92 throttle body
-trunnions upgrade
-PRC Texas speed LS6 heads CNC ported
-ARP head studs
-Texas Speed 228R cam/correct pushrods
-SLP double chain and SLP high volume oil pump
-ATI balancer
-New Corvette accesories
-PSI stand alone harness and ECM
-Last Chassis dyno was 460hp to the tires. Might throw in the mcleod clutch
It's basically a complete everything you need LS Swap. Add fuel system, exhaust, some electrical connections and its ready to go. Potential buyer can hear it run and even test drive it.
Value?
I'm thinking around $6k
