More updates can be found on
www.gearheaddaily.com too if I don't always post on the build threads. Just throwing it out there
Well folks, fall is officially here in Minnesota and it’s starting to get colder. I hope you enjoyed summer because completely over with. Kaput.
I’ve been working a couple hours per night on the car whenever I get a chance. I’m not that confident with fiberglass so this has been a decent learning experience. Let’s get down to it.
I was able to finish installing the lights and lens cover on the passenger side of the from clam. This is a bit of work to get everything just right. I know it looks a bit chaotic from some of the previous pics, but if you take it slow and take it in small chunks, it makes life a lot easier.
The tail lights provided their own challenge as there isn’t a clear way to attach the lenses (borrowed from a Dodge Dakota, seriously, take a look at one some time!). I took the better part of an afternoon to make sure these fit tight and as close as possible. I will have to back fill them with fiberglass at some point, but that point isn’t now.
Now, as parts get put on the car, so does my list of custom tools. This is the first “fun car” that I have owned that will have AC so I’ve had no need for an AC hose crimper.
I decided that since the name “Stormtrooper” came up a bunch lately, it made sense to add a few black accents to the body. When the doors are closed you won’t be able to see much of the black, but when you open that and the front and rear clam you’ll see the accents to the color. I had some issues with tape sticking to the body after using some “Goof-Off” sticker remover so that’s why I have all the over spray issues. I tried several kinds of tape and had come to the conclusion that there was some residue on the body keeping it from sticking. I tried a couple solvents with no avail. I reinstalled the doors and will attack the overspray soon. I’ve found that brake cleaner eats right through this type of paint! Easy and cheap fix!
I think I may have figured out the engine situation for “Griftrooper”, here’s a small hint…. Giggity.
