Old 04-28-2016, 02:25 PM
It looks nice Rusty.
Old 06-04-2016, 02:58 PM
GPR's Avatar
GPR GPR is offline
I have been busy working in the shop and I need to update
I block sanded the fiberglass hood
Sprayed one coat of SPI black epoxy
Two Coats of SPI Turbo primer
Block sanded again
Two coats of SPI epoxy
The fiberglass bumper did not fit our car. The center section did not line up with the lower valance and the bumper was to narrow.
I cut the center out of the bumper and had to modify the holes in the taillight panel to get the bumper lowered.
I used Duraglass to attach the brackets to the bumper. Later I added a couple layers of fiberglass to hold them in place
This shows you have much I need to add to the left side
I added fiberglass to the top to hold it in place
I clamped it to a long piece of angle and added fiberglass on the back side.
I removed the braces and clamps and finished adding fiberglass to both sides and this is how it looks now. I still have to work on the gaps.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 06-08-2016, 10:53 AM
Good job, Rusty! Looks a lot better now
Old 06-09-2016, 05:04 PM
GPR's Avatar
GPR GPR is offline
I epoxy primed the bumper and test fit
It still needed a little bodywork
Epoxy primed again
Rusty Gillis
Port Richey Fl
Old 06-11-2016, 11:26 AM
GPR's Avatar
GPR GPR is offline
This project will be on hold for a little while.
Rusty Gillis
Port Richey Fl
Old 08-03-2016, 06:49 AM
GPR's Avatar
GPR GPR is offline
We are back working on this project. I had to do a little bodywork on the front of the fenders to get them to line up to the new front valance and epoxy primed.
Front valance and rear bumper block sanded and epoxy primed
Test fitting one more time
Rusty Gillis
Port Richey Fl
Old 10-05-2016, 07:45 PM
GPR's Avatar
GPR GPR is offline
We have been working on this doing a lot of little things to make it look right. The hood did not line up with the headlight buckets so I had to add fiberglass to the end of the hood.
Brian test fit all the door glass, vent windows, quarter windows, windshield and back glass moldings
This area needed a little work
I worked on the body lines
As you can see in this photo the front valance was a little high and the fender had a low spot that needed bodywork
In the middle of a lot of block sanding and looking for any imperfections
Rusty Gillis
Port Richey Fl
Old 10-08-2016, 07:37 AM
kttrucks's Avatar
kttrucks kttrucks is offline
Rusty, This is going to be a great car! Very nice work! You guys always kick out great craftsmanship and this car is certainly no exception! Can't wait to see it finished.
KT
PTFB, Viking, Holley Performance Products, BFGoodrich, Heatshield Products, Turbonetics, Hellion Turbo Systems,TCI, Dennys driveshafts, Eastwood, Preferredline Media, Summit Racing, Strange Engineering, Forgeline, TMI Products, DBR High Performance, Spectre Performance, Vintage Air, NPD, Digitails, Redline Lumtronix, Dakota Digital, Newport Engineering, Stage 8 fasteners, Industrial Depot, Brian Finch, Grant Salter, and many more Good friends with big hearts.
Old 10-08-2016, 09:11 AM
gofastwclass gofastwclass is offline
Excellent fabrication work and attention to detail. Thank you for sharing.
Old 10-19-2016, 03:19 PM
GPR's Avatar
GPR GPR is offline
The back of the hood was sanded and epoxy primed
Block sanded the body and epoxy primed
The trunk was sanded and epoxy primed
The engine compartment was sanded and epoxy primed
Rusty Gillis
Port Richey Fl
