119 hours At this point I started to have a whole new appreciation for people that do body work day in and day out. Miserable!!!
IF you purchase a new hood, order it in two pieces and bond it together yourself with 3m panel bond. This hood fit like crap and it is supposed to be the best on the market
This was the worst fitting spot on the hood.
Before
After
Before-Zero space on passenger side
After
Front Before-No space and sat way too low at front edges.
After
Driver's side before-too wide
Driver's side after
Had an issue with the headlamp bucket...the casing was too narrow and the bezel was to wide. So, i has to shave the edge of the bezel and build up the casing. Once i had it properly aligned, i had to build up the inboard corner and the front of the casing at the lower nose portion of the surround.
Before
After
Both Required attention, but the driver's side was not nearly as bad.
Front of driver's door is finally finished
